Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
torquing connecting rod caps head bolts
jim_uny
02-08-2018 16:14:16
when one torques connecting rod caps or head bolts do you put some 5 weight oil on threads ? why is this done ? if not why do you leave them dry
jim_uny
02-08-2018 22:20:47
 Re: torquing connecting rod caps head bolts in reply to jim_uny, 02-08-2018 16:14:16
will try again for better hyperlink to http://arp-bolts.com/p/FAQ.php
jim_uny
02-08-2018 22:18:25
i found this on ARP-BOLTS.COM faqs section. i think they should knew
rustred
02-08-2018 17:26:14
in the auto or engine industry thread torque is taken as clean and oiled. its pretty much torque values for oiled threads. oiled threads require less torque than a dry thread. i would guess at 10 percent less.
wilma
02-08-2018 16:36:39
The little bit of light oil on the threads lubricates just enough so you get a correct torque. If you have ever tried to thread a slightly rusted or dry nut onto a bold and noticed it "binds" a little then goes? That little bit of binding could cause a loose rod or a head gasket to fail. Hope this explanation is helpful.
