We have recently picked up an Oliver 99 that has the 443 gas engine, with the M&W 5” overbore kit in it. The engine was stuck, we have disassembled it and are now looking for some parts. The first question is: where can gaskets be found? Primarily a headgasket. I’m sure that other gaskets can be cut out from gasket material if needed, or RTV silicone may be our friend. I believe that our pistons can be reinstalled with new rings, however two of the sleeves are questionable. Does anyone know where there might be a couple of sleeves, either in the 4.75” bore, or the 5” bore? This tractor also has a live hydraulic kit that drives off of the back of the distributor. We do not wish to reinstall the live hydraulics, what pieces will we need to put it back together without the live hydraulics?
Thanks in advance for any and all assistance!!!
