Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
front end swap on 1650
relink
02-07-2018 04:34:33
Going to switch out a narrow front for a wide front. My question is when I have the front end off should I replace anything while the tractor is a part? Recommendations?
Mike(NEOhio)
02-08-2018 14:51:51
 Re: front end swap on 1650 in reply to relink, 02-07-2018 04:34:33
I would suggest checking a parts book. WF and NF may use a different steering shaft.
1970-1655
02-07-2018 12:20:57
To pull the PS cylinder out for rebuild do I need to pull the radiator? Can I pull the shaft out and pull the cylinder with radiator still in? I just got done wrestling the radiator but after I got done I noticed PS leaking. I know, I should have checked it while I was in there but time and below zero were not in my favor.
rrlund
02-07-2018 13:55:56
 Re: front end swap on 1650 in reply to 1970-1655, 02-07-2018 12:20:57
I usually pull the radiator and leave the grill on. Take the cap off the top of the cylinder,loosen the big bolt,it'll come up tight again. Keep going. It works as a puller. Pop the gear off and then lift the cylinder out.
1970-1655
02-07-2018 13:59:21
 Re: front end swap on 1650 in reply to rrlund, 02-07-2018 13:55:56
Thanks. Now to get a day warm enough and not raining or snowing.
Married2Allis
02-07-2018 08:34:26
Would also replace the pair of pittman shaft needle bearings and seals (2 each) that sit under the PS cylinder. About $75.
rrlund
02-07-2018 07:09:08
Like CO said,at the very least replace the quad ring in the cylinder,but you can buy the entire o-ring and quad ring kit most places for $25. No big deal at all to rebuild. Tap the end cap in,take out the wire ring,then tap the whole unit down on end between two blocks and it'll all pop apart.
Traditional Farmer
02-07-2018 06:16:40
Are you going to sell the NF?
relink
02-08-2018 04:55:57
 Re: front end swap on 1650 in reply to Traditional Farmer, 02-07-2018 06:16:40
No not at this time.
carolina oliver
02-07-2018 05:29:19
You might want to take the PS cylinder out then, put kit in, maybe hone the cylinder if needed.. pretty easy job and insures THAT part is all good.
