ol 1650 w/ white 2-70 3 speed
jim_uny
i want to upgrade my oliver 1650 with a white 2-70 3 speed. will it work & fit ? any extra parts needed ? txs
If your 1650 does not currently have an over/under or hydra-power you will need to drill and tap the bathtub to install a support bolt. Search the archives here as there was a post a few years ago that had a good set of pictures.
Jim, Do you have the dash from the 2-70? Remember to pull engine and Hydra Power out together as J. Shweibert suggests. Also pull PTO drive shaft out first. On the 2-70 do you have all the tractor just wondering if it might be my old one?
You can also use an automotive trans cooler and rubber lines. Is your hydrapower cooler good with no leaks? I might be interested. Email is open.
