After 3 years of saying I was going to do it, I finally bought a set of new Deep Tread Radials for the 1955. Did the duals to so it was a pretty painful check to write but worth every penny in my opinion. The tractor rims had chloride damage so those were sandblasted and repainted along with new paint on the dual rims. Didnt load the tires this time in the hopes that having a good set of rubber on it for the first time will offset the need for more weight. I figure if anything else I can throw more wheel weights on it cause Im tired of dealing with leaking water valves and rusted rims. Now the only problem is the rear tires make the fronts look like crap so those are probably going to get replaced. With how much taller the Deep Treads are may have to look at jumping up to 16's on the front to level it back out.
