Engine Swap Question (Oliver 88 to Oliver 77 RC)
JBart
What all has to be changed, to put an Oliver 88 engine, in a Oliver 77 Row Crop?
Any advice appreciated.
The 88 engine is a 1/2 '' longer will bolt right in 77 frame.Need to cut pto shaft a 1/2 on plined end and hollow shaft from 77 I think will work I did this 30 years
ago.Water pump needs a shorter shaft maybe or press pulley further on.I think I used the 77 bell housing and beefed up the clutch.It will work.
