can anyone tell me where the level plug is for the rear diff and trans. on an 880 oliver. all I see is a 1/4 inch plug on the pto housing. I put in too much oil I think. 1/2 way up axle shafts and it is leaking out by the brakes?
(quoted from post at 11:39:47 01/01/18) can anyone tell me where the level plug is for the rear diff and trans. on an 880 oliver. all I see is a 1/4 inch plug on the pto housing. I put in too much oil I think. 1/2 way up axle shafts and it is leaking out by the brakes?
It is on the right below and back from the axle.
On the 880 tractor the check plug is on the right ahead of the axle. Did you drain both the transmission and the final drives? Capacity for both of those is 19 quart.
so I seen the plug but just assumed it was so low in the system it was a drain plug on the side. thanks for the info.
(quoted from post at 12:21:44 01/03/18) Is that the same capacity for a 88, I thought they were 18 quarts?
I don't know what the capacity would be. I just thought the plug in front of the axle seemed a bit low to be a level plug but maybe it is the one.
