Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Oliver 90/99 water pump
kwf
12-31-2017 09:28:21
Hey,
I need the parts to rebuild a water pump on an unstyled Oliver 99 4-cylinder tractor. I know there has been some topics on this before, didn't know if anyone had part numbers or places to get the parts to rebuild this water pump. Thanks.
oliver90owner
01-01-2018 01:40:48
 Re: Oliver 90/99 water pump in reply to kwf, 12-31-2017 09:28:21
Back over 30 years ago, I found the pump shaft a little rough due to, presumably, some leakage past the carbon seal and the bearings shot due to the housing being filled solid with hardened sludge. I replaced the seal with one made from a motor brush, replaced the oilite bearings (I drilled them out as they were too small - not the best way to do it!) and used an electrical cable sealing cover boot as well. This was obviously before the inter web and no spares were available on my side of the pond.
It leaked oil (as they always apparently did) but has not been a problem since. The tractor doesn’t get run much, mind. I am confident the repair will outlast me.
lstra
12-31-2017 18:34:09
Commercial Water Pump in Houston, Area Code is most likely 713.
Mike(NEOhio)
12-31-2017 17:10:17
Kellog Automotive in Maricopa, Az.
wilson ind
12-31-2017 16:15:46
Commercial pump Houston TX 712 864 5199 can rebuild about any h 2o pump
