77 Ignition switch
60 Fan
Have purchased a new Ignition switch,ignition harness as well as light wiring harness for a 77 that had OEM wires gone and used a push pull to run and no wires to ammeter. The wiring diagrams supplied and that I have found are to me very vague and hard to read as far as exactly where each wire connects on ignition switch and to 4 way fuse block. Can anyone help me out with pictures and color codes to exact terminals for a six volt positive ground '51 77? Thanks in advance.
Thanks for reply. The diagram obtained off this site is essentially the one I have been using, however even after expanding to 175% is difficult to ascertain correct placement of wires to ignition switch. The one purchased is ever so slightly different than diagram and detail is not there for these older eyes.
Good Afternoon: Email does not seem to be open and private message is not available at this time..
Serial# 345272 TLBuelow at aol dot com
Thanks.
