Help deciding what Oliver tu buy
chas036
I want to buy an oliver mainly for running my 6ft snow blower , so I want one with a low reverse speed. The reason I want an oliver over other tractors is because of how easy it is to work on them. I would much rather lift an engine than split a tractor to replace a clutch. I would like something around 50 to 60 HP and I don't want to spend more than $5000
1650 gas with hydra power low reverse 2.3 mph. Bad thing is with no cab might be a little chilly. See quite a few around 5000. Also hydra power has no brake effect in under. 3 point dual hydralic real reliable tractors
I run a 1650 with a 6ft snowblower. 1st gear in hydrapower low range is a little fast in deep snow, but otherwise works good. I had to extend the width of the blower to about 96" to handle the 90" tire width so I bolted on some 3/16 steel plates about 24x24".
1800 c diesel is a good old tractor. A little more HP than you stated, but it never hurts to have too much HP.
