Fleetline sealed beams
A while back I cleaned up some 5 3/4" Guide light buckets off of a fleetline to use on my 77. I didnt realize they were for a sealed beam bulb and are different from the type with a reflector and small bulb. My question is, where can I get sealed beams to fit? I bought some from NAPA (floodlight type I guess you would call) but they didnt fit. Close but different. Anyone have a part number that will work? Thanks in advance!
On a Case 400 I replaced the the bulb and reflector unit (which didn't have a replaceable bulb) with a sealed beam. I put a bead of silicone around the shell and set the beam onto it. After it cured I tightened the ring. I don't remember the sealed beam number that I used right off hand.
(quoted from post at 00:58:36 12/04/17) A while back I cleaned up some 5 3/4" Guide light buckets off of a fleetline to use on my 77. I didnt realize they were for a sealed beam bulb and are different from the type with a reflector and small bulb. My question is, where can I get sealed beams to fit? I bought some from NAPA (floodlight type I guess you would call) but they didnt fit. Close but different. Anyone have a part number that will work? Thanks in advance!
Several years ago I got sealed beams from my local Agco dealer. He found one that was used on a combine. Was 102213A. Worked in my old shells that originally had the reflector with separate bulb. I have a 88 diesel, so these are 12 volt.
