White 2-155 mfwd
kb88
Hello
I was wondering what kind of turning radius a 2-155 mfwd has? Will it go back in with a 12-30 planter? And will they row narrow enough for 30" rows?
Thank you!
I have a series III that is set for 30 inch rows. I have pulled a six row Rawson strip till unit hooked to a JD 7000 planter with it. A white with MFWD turns pretty tight. Al
I found a .pdf thru a google search that shows 13-19 foot radius depending if the front axle is engaged or not and if the brakes are used or not.
