Super 55 shifter
770jdman
Been working on super55. Had a few minor things left. I tried it out on the bush hog before i put it up. Everything worked fine. Well of course i put in the corner for to long and used other tractors. Went to move it around and now the shifter will not go in any gear and it's stuck in the upper nuetral and won't go into the lower quadrant. Any ideas. Thanks in advance
brought home a 550 that had set for 15yrs seemed to shift nok put tractor in gear chained it down drove 2hours home and wouldnt shift out of gear oiled up though the shifter hole finnaly got it out of gear took the trans cover off and the shifting rod had bolts loosened up causing shifter to bind up tighten all the bolts up no more troubles pain but not as bad as replacing crewed up gears
