Need help with pump
KLPinNC
I can not get the diaphragm to come out.
The pump rocker link will not pull out.
(quoted from post at 19:01:03 11/25/17) I can not get the diaphragm to come out.
It's been awhile but I think you need to remove the lever and pull the rod out.
The pump rocker should NOT pull out like that! You need to push down on the diaphragm to compress the spring and then unhook the diaphragm.
(quoted from post at 20:55:07 11/25/17) The pump rocker should NOT pull out like that! You need to push down on the diaphragm to compress the spring and then unhook the diaphragm.
Thanks J. I couldn't remember. I might have removed mine but didn't need to. When I found out it was missing check valves and the kit didn't have them I put it all in a box and it's still there.
Hi:
Do you have a replacement diaphragm? As J said it should be push down and push away from the pump leaver to unhook. Where did you get the daphragm from?
