oliver 60 wont start
bessie
New User
only starts after I squirt gas in a cylinder then will run and start the rest of the day but the next day the plugs are dry not getting gas to cylinders but pours out the carb
well I cleaned the carb twice but I was wondering if it might need a kit I will get one put in and see what happens
(quoted from post at 22:13:14 11/26/17) Small air leak into inlet manifold when cold? Valve clearances? Slow running jet blocked? Seems like it needs a service.
RAB
im wondering about a intake leak cause once you've started it it will start right up again then overnight im losing my compression I think...valves should be set correctly and imnot sure what a slow running jet is ?
Carburettors have differing designs to maintain the correct mixture at different air flows (engine speeds, basically). There will be a smaller fuel delivery jet, for slow running, and a
much larger one for power - working under load.
Some have some seriously complex means of fuel delivery but the 60 carburettor is a fairly basic device.
