TractorLinks.com
Show Parts for Model:
1365 loader hydraulic pump
StrongsOlivers
11-13-2017 06:30:23
I'd like to get my loader back on my 1365 but the pump is junk. Does anyone have part numbers for one or where to find one. It appears to be the same hydraulic pump that's on my Gleaner f2, only the 1365s has a splined shaft.
Thanks
Traditional Farmer
11-14-2017 00:18:08
 Re: 1365 loader hydraulic pump in reply to StrongsOlivers, 11-13-2017 06:30:23
Another source is Surplus Center they have a lot of hydraulic pumps you should be able to match one up.
jim_uny
11-13-2017 17:39:07
a & i products has A-5129488 Pump, Hydraulic (42 Litres/Min.) for a loader. CCW Rotation. Top port size is 0.560" & bottom port size is 0.740". Flow rate is 42 liters per minute. made by fiat. cost is approx $ 200 plus s/h. contact a dealer.
rrlund
11-14-2017 03:57:26
 Re: 1365 loader hydraulic pump in reply to jim_uny, 11-13-2017 17:39:07
The one I got from Rick was from Sparex. It was cheaper.
J. Schwiebert
11-13-2017 09:46:46
There are also formulas out there where you measure up the old pump and look in a pump manufactures catalog and then using those specifications replace it with a new brand x pump. IT is done in the truck world all the time. The key thing is selecting the correct rotation and port size.
rrlund
11-13-2017 09:21:00
Is yours on the back above the PTO? Call Rick at Ricksagparts dot com,he should have one. I don't think they're very expansive. I got one of the pumps on the side of the engine for the 3pt and remotes a few months ago for less than $200. That rear pump is about the same size.
StrongsOlivers
11-13-2017 13:09:15
 Re: 1365 loader hydraulic pump in reply to rrlund, 11-13-2017 09:21:00
It's the pump right above the pto, but I do need the 3point pump too. The hydraulics on this poor thing got water in them both tractor hydraulics and loader.
rrlund
11-13-2017 14:22:32
 Re: 1365 loader hydraulic pump in reply to StrongsOlivers, 11-13-2017 13:09:15
I'm thinking that engine side pump was only something like $160. I got the pump,drive hub,gasket and O-rings,with shipping it was under $200. Rick had one on hand and had it to me the next day. I've got one of those rear pumps here that I took off a 1250 in the scrap yard. I don't know if it's good or not. I'd just as soon keep it though in case I need it for mine. I got both pumps off it thinking that side pump was the same,but the inlet on that one is smaller on the 1250.
wisconsin cowman
11-13-2017 06:58:30
Any numbers on the pump also what model of loader?
StrongsOlivers
11-13-2017 13:05:37
 Re: 1365 loader hydraulic pump in reply to wisconsin cowman, 11-13-2017 06:58:30
I don't know the pump number, I can look though. I have two pumps one is the original which runs the loader like a snail and the other will make the loader move! The loader model is a 1512 or 1514, I can't remember. Its the loader that came with the 2wd.
