Seal for Oliver 60
torval
I need a seal for the trip lever on the power unit on an Oliver 60 Row Crop. Book number is b-1518.
Maibach says it is obsolete and discontinued. Anyone know where I might find one? Have not take it out yet, because restoration is about complete and I don't want to take it out and not be able to get one.
John Deere part # AN113330 is really close. It is a bit shy on the OD. I used silicone on the outside of the seal. It should fix the leak, but if you use it much it may not last. Just went through this on
a 66(same B1518 part #).
(quoted from post at 14:19:34 10/20/17) John Deere part # AN113330 is really close. It is a bit shy on the OD. I used silicone on the outside of the seal. It should fix the leak, but if you use it much it may not last. Just went through this on
Thanks for the information. It won,t get used much if at all. Jusy want to stop the leak.
Wonder if you could use a speedy sleeve to up the shaft size. Have not tore into mine but there surely is something that will work.
(quoted from post at 21:01:36 10/22/17) Wonder if you could use a speedy sleeve to up the shaft size. Have not tore into mine but there surely is something that will work.
I got the John Deere seal and when I took the old seal out it was cork. The new seal fit very well with some silicone around the outside, I don't think it will leak at all. Has not so far anyway. Drove it about two miles and no leaks. Don't plan to use the power lift anyway, just wanted the leak stopped. Thanks for your help.
