gordey
Anbody know of an alternate application that has he same torque converter as the 995, need the whole thing. Thanks
Call Joseph Industries in Steetsboro (sp?) Ohio 330-528-0091. They've been at it a long time, and should be able to get you a cross. Have your dimensions, spline count(s) etc. when you call.
That is where we sent our converters and reverse-o-torque units when I was at the White dealer in the '80s- '90s.
It is quite possible. The engine and converter combination
would have been readily available from DDA distributor. They
were both GM products.
The PTO shaft through the converter might be an issue,
though.
I know the tc is an allison part and I should be able to find it, but I need the model of the torque converter in the tractor so that I can start looking for the right one, as mine is missing. Thanks
Gordy, I went to AGCO parts book and after checking in as guest user put Oliver 995 in the search box. Converter assembly torque, Allison P/N 6759643 alternate 102705 AS. Check it out if you can it has total parts breakdown for 995.
