For some reason or another, I cant reply directly to posts. On previous block there was an access port to oil galley on lower right side of block. Tapped into it and run a line outside the block up and over valve cover then drilled a hole in valve cover and run a short pipe down into rocker arm shaft.
Plugged hole on head bolt.Gets good supply of oil to rocker arms. My oil pump held good pressure at oil gauge, so i determined pump was good. This may not suit everyone to do this
, but it solved my issue as I have done it before. The reason I had trouble this time was that this block had lower oil port located in different area than my previous block. I hope this explains the problem I had.
