StrongsOlivers
Today I hooked the 5 bottom plow(first time using the three point in 10 years) to 1855 and tried to do a pass, but the three point won't go down all the way. The moldboards barley scrape the ground and picked up all the way there's about 8 inches from ground to the bottom of the Moldboard. So what I'm asking is is there a adjustment for three point travel? Cause when I push the lever down the arms go down but stop about 2 feet from the ground. My 2-135's arms when all the way down almost drag on the ground. And when i pull back the lever they only come up a foot or so. Also so I'll add that the lever only does anything on the bottom three inches of the lever console. I confused anything in the shop manual So I wanted to consult you guys on here before I do anything.
