Oliver super 55 and 550
How many different types of rear wheel weights were available for this tractor? I am thinking factory additional equipment.
Are the wheel weights from a Farmall A or VAC Case close to the same?
I know the spin out rear wheels take different weights than the regular wheels. Other than that I would need to look.
There are three used on the Super 55 & 550.
E-1235 was used on pressed steel non Power adjust.
100 048A was used on Power adjust 28" wheels
102 318A was used on Power adjust 26" wheels.
You should be able to find these numbers cast into the weights
