I have a friend who has a Oliver model 550 construction tractor.
He removed the injection pump prior to setting injection timing and replaced the pump. What are the degrees BTDC ?
The injectors have been rebuilt. When cranking, the engine has heavy smoke and will not start on starting fluid. One person gave up on trying to get it to run after trying several different timing
settings, Any help will be appreciated.
