Rod bearing
Just a follow up on my rod bearing problem. John you were right on with your answer. I had the connector rod sized and it was actually to small. This is the cylinder that i found the bad rod bearing in. I don't know how the person before me got the motor to turn. Less torque on that Rod? Had a machine shop size it properly, will try to put it in tomorrow.
