value of 1365 2wd with loader
deene
I found a 2wd 1365 with loader that's being sold...has to be pull started as the electrical system is bad or so they say so starter wont work...also has a weak clutch...otherwise tractor doesn't look to bad..both fenders are rusted pretty bad at the bottom but still solid enough not to move back and forth..good rubber with pwr steering...haven't heard it run yet..i noticed below oldabe replaced a clutch in one is this a big job?...I wish it was a fwd like rrlunds but what would something like this be worth in southern ill....mod number is 535 22035 and ser number is 707 693 thanks for all replies
$2000 maybe. I gave $5700 for my FWA,delivered. They're not hard to put a clutch in,but if that pressure plate unit is worn too bad,it can be pricy.
thanks randy I was hoping to catch you on here so I will go listen to it run and see if anything else is amiss and go from there...thanks again
Don't let the pressure plate scare you off. If hasn't gone too far,you're good. I got the clutch refaced and a new pressure plate though Clutch Dynamics in Lansing Michigan for something like $640. Pricy is a relative term.
thanks j will do that if I get it bought...being a loader tractor I can see where it would be weak...but the tires are good no spinning so that is either 2 things..not abused to bad..or clutch not holding enough to spin the tires..lol
Gave $700.00 for mine. Had to rebuild the steering cylinder and change the hydraulic fluid and filter. Took the loader off as I have other tractors with loaders. Guy just wanted to sell and go back to California. Probably about $2000- 3000 as was already said.
I have a 2WD and a 4WD 1365 both good tractors,,but I'll say unless I really need 4WD I'll use the 2WD for things like unloading hay bales because its a lot more
nimble and a shorter turning radius.As far as the starter you can get a starter off ebay that's listed for a Long 560 for around $120 it fits the 1365 perfectly and is a better starter
than the original 1365 starter, have one on each of mine.I put in a clutch and did other work on my 4WD drive when I bought it,knew it needed work.AGKITS has the complete clutch set up with the
clutch pack already set up ready to install for $575,includes both disks,both throw out bearings and pilot bearing.Been running it now for about 2 years with no issues.If you don't care about
being original fenders off a AC 5050,5040 and many of the Long tractors can be installed on the 1365.
