1944 Oliver 70 smoking need advice
Elkurck
New User
Im sorry if this is a repeat but i have an excellent running 70 that at an idle will fog the mosquitos for a quarter mile. Could it be the valve guide seals or does it needs a set of rings? If it could be valve guide seals which should i get?
When I was with Dana Perfect Circle had many styles of valve seals. My e-mail should be open send me a reply and we can discuss it. It probably has been 50 years since I have had a 70 running with the valve cover off! J.
I havent had the valve cover off yet but with the amount of oil used not to mention its just plain embarrasing to take a tractor somewhere thats smokes so badly at an idle. Do i need to pull the hood & valve cover to investigate further?
(quoted from post at 19:05:29 09/21/17) Im sorry if this is a repeat but i have an excellent running 70 that at an idle will fog the mosquitos for a quarter mile. Could it be the valve guide seals or does it needs a set of rings? If it could be valve guide seals which should i get?
Get it on the patch. Seems like I was told they didn't have seals. May need guides
(quoted from post at 20:41:59 09/23/17) im still new to this but i couldnt find your email. Knowing me im probably just looking over it.u
You will need to log in under classic view to email J and if his email is open it will list it under his post.
your email still isnt active. Mine is you could email me then we discuss this tractor problem. Thanks.
