Finally getting close to being done with the 105 project although still a couple things to attend to.
Hooked to the baler
Baling straw
Noticed the PTO control valve wouldn't stay locked in the engaged position. What would the issue be? A worn dent ball or spool? Haven't disassembled the valve yet. But I put a new O-ring on the dent piston when I rebuilt the PTO unite.
Also the AC to service but supposed to have a guy come and test it to find any leaks before trying to recharge it. May have issues with the compressor or condenser as it has a damaged area. The condenser fans run ok however.
Otherwise it is running smooth. Makes her work a little and blow a little black smoke when the bale is nearly full size.
Any suggestions on the PTO valve would be appreciated.
Hooked to the baler
Baling straw
