pulling tractors
KURK1
About 10 years ago I watched a couple utube videos of a 1950 Detroit powered puller and a 2255 with a cat. Both owned by the same person I believe, in Wisconsin or Minnesota. Both had the appearance of a stock tractor but were way more than that!! Does anyone know where I can find that again?
Those tractors you mention came factory equipped with the mentioned engines. The 2255 came with two variations of Cat V8's depending on the year. The later 2255's had 3208 Cat, the earlier had the older 3150, (I believe it was called,) Cat V8. The 1950 and 880 came with Detroits.
"The 1950 and 880 came with Detroits"
The 880 had only Oliver/Waukesha engines.
The 990 and Super 99gm, and 995 had the Detroit 3-71 engines.
