Calvin Innes
I came home yesterday with an Oliver Industrial 66.... not running, but I suspect it will be an easy machine to fire up.
It has serial No. 462280C66E. I don't know what year it is but I'm thinking it is a 1964 based on the serial number. Am I close?
Interesting tractor, it has a side mounted sickle bar but I don't know if it is an Oliver Mower. Did Oliver ever make a hydraulic side mounted mower?
Does this tractor use common parts with the 66 standard or 66 fleetline? Most of the sheetmetal looks the same as does the drive line.
Thanks for any info you folks can give me.
