OliverNate
Took the carb off the 18-28 to clean and make new gaskets, had everything sitting on the bench in such a way that I could remember how to put back together. Well it sat out to long and some stuff kinda moved and now I can't remember what goes where. The one picture is of two ports one is solid and one has hole drilled and other picture is of three ports one is solid and two have hole drilled one has 55 and other has 52 stamped in it. I have them in the ports that I think are correct other than the fact that on the three port picture I don't know which number of plug goes where. Hoping somebody has something or can give some insight cause no excited about guessing and take carb apart 20 times.
