371 Detroit
Jshum40
I have an Oliver super 99that I need a secondary fuel filter canister for it. I also may need the filter housing if I can't get it to stop leaking. Does anyone know where I can find one? I would prefer it to be close to Southeastern Il, Thanks I advance, Jim
Not real familiar with that application. Is it the same as most 371 Detroit's? Do you have a pic? I know where there is a tiling rig in the scrap yard with a 371 on it.
No, I don't have a picture but where is this loacated and do you have a phone # ? Thanks for your help.
Is it leaking where the gasket goes in between the bowl and the top housing? Check and make sure the gasket is large enough to seal the bowl. I have four GM powered Olivers and Once I had the secondary filter leak and on another the oil filter base and both times the gasket I got with my new filter was too small. The filter companies assume a "one size fits many applications" and its not true.
I'm sure, because the gasket fits in tight, but I'll check it and get another gasket and put it on. It has leaked and I've had I've had it off about 6 times, so the gasket may be ruined. Thanks for the reply, as I appreciate it.
Check the bottom of the canister it can get pulled up and the bolt bottoms out inside of canister before the gasket can seal
