1750 front hub lub question
jhwis
What goes in the front hubs on the 1750? Is
it grease? I can't remember? The hub around
the spindle. Two wheel drive....
The simple answer to your question is yes it is grease.
Are you replacing the bearings? They should be packed with grease before you replace them. If you are wanting to add lubrication. pump some grease in the grease fitting on the hub.
Lloyd
The early 50 series used a 3/8 pipe plug and were filled with SAE 90. A some point a service bulletin was issued to add a reducer and grease fitting and pack the bearings.
