OliverNate
Friend of mine has a 1800C that he plumbed for power beyond for a loader joystick. Its not working the way it should. One of the problems was he had the by-pass/return hose plumbed into the 1" return port. Other problem is he didn't put in the plug inside the supply port. All the directions I've seen say to remove the 1/2" plug and put a 3/8" plug down inside the 1/2" port. The problem is on this 1800C (I looked at my 1800C as well and its same) is that the port that the directions say should be a 1/2" is actually a 3/8". So is the threads that are inside this 3/8" port 1/4" or is this not something you can do on this model? I'm unable to look in the hole on my 1800C cause I don't have any 5/16 key stock to take the plug out.
