I am collaborating with myself to restore a nice Oliver 0C-3 Dozer. I have painted it orange because I like it that way.
Now -- during resto I took lots of photos, but they evaporated from my camera.
Everything is good except it won't start now. I was running well when I began.
Starter works, I've got positive ground, 6.53 volts battery; the ammeter may be cooked, but the old one was too, when it ran.
Sparking plug wires are correct. Coil is most likely fine -- I've never had one fail.
Can someone look at the photos to see if I have it wired correctly? Does the panel have to be bolted to the support and therefore grounded?
Previous owner installed electronic ignition; I didn't touch it -- all connections are bare metal (and painted orange).
I've tried to make the photos clear. I've also installed some photos of the project for you to like.
