Olliejunkie
Is there anyway to check pump pressure on tractor? Local shop want $250 plus to check it after they already charged $100 to clean and reassemble the head. I cannot get the injectors to pop. I have bench tested them at 1750.
I pulled this head off another unit and believe that it is timed properly. I pulled all the lines off and turned it over. Fuel pumps out but doesn't squirt up at all. Pulled the head back out and the plunger still seems ok. Maybe it's just wore out but it seems the shop would've caught that. All previous help and future help and suggestions are very appreciated.
