fixerupper
The fan has been dangerously close to the generator on my 88 since I've owned it. One blade started hitting end of the generator shaft (armature) the other day. When I investigated it I found a cracked blade so I got a new fan. The blades on the new fan come 1/16" from the end of the end of the genny shaft, way too close for comfort. is there supposed to be a spacer between the fan and water pump hub on this thing? The stub in the middle of the fan hub sticks out a good 1/2" beyond the water pump hub when the fan is installed. It just looks to me like it should have a spacer in there. Thanks. Jim
