Art Eby
hello, Could someone post a picture of the wiring behind the gauges on an Oliver 77 diesel? i am redoing the wiring and would like to see which wires go through which grommets etc. thanks
Does your tractor have hydra-lectric and if so a group 1, 2 or 3? You might be able to simplify that wiring a little bit.
yes it has hydra-lectric. Not sure what is meant by group 1,2 or 3. It has two hydra-lectric valves.
On another subject... does anyone know where to get replacement hydra-lectric valve switches?
thanks
Are the switches by the steering wheel? If so what is the problem with yours. You understand how those units work? Send me an e-mail. J,
