2-155 fwa on 135
How much do you think this weighs?
[b:654c4848f0]How does that go in?[/b:654c4848f0] It's the last thing you will take out of the 2-155 after you take everything else out of the housing, will only have a reverse idler left.  Same for the 2-135, it's the first thing in the housing after removing everything.
You are looking at it backwards, find out the condition of the 2-155, if OK move the 2-135 components to the 2-155.   If you are not able to perform the transfer, set up all the bearings, shop equipment and etc. and have to have someone else (the pieces are big and heavy, will take two people) do the transfer you will have a bigger labor bill than the tractor is worth!
