Finished installing the engine in the tractor and had it running warming up to reset the valves.
Problem is the sealing ring around the pipe to rocker shaft oil tube pops out after it warms up and sprays oil all over.
I carefully installed a new sealing ring when reassembling the rocker shaft to the head. When it first happened I loosened the shaft and pressed this ring back into place on the pipe but it popped up again.
I can get another new one but I would appreciate any advice as to what might be causing the problem. The oil pressure gauge indicates the oil pressure in the upper 3/4 of the green but does not appear to run too high on the gauge.
Thanks for any suggestions
