1750 inj. pump
cuby
I have the pump {Roosa Master} off this tractor for a rebuild. Wondering if there is a way to install pump onto shaft with the seals already installed without the speacial tool that the I&T manual says is needed.
All info is appreciated.
Thanks
I always removed the shaft and installed the shaft and seals in the pump. Use plenty of grease. I hope you aligned the timing marks before you took the pump off!
Pumps I repair have the brass tube bevel angle changed similar to the steel tubes, seals then enter much easier with to tools, just lube well and use fingers..
