buzzinduzzin
- Location
- se illinois
Bought a 2-155 a couple of years ago. All it really has done is pull a 20' bushog . The pto has always worked fine & handled max torque
with no slippage (to the best of my knowledge). Had to install a new stump jumper on R.H. wing & took out for an ops check in fairly heavy
fescue, engaged & advanced throttle, let out clutch & all was well for about 50' then realized mower had lost a lot of rpm's (but tractor
engine did not). Shut down, restarted same results! Then I tried swiftly engaging at approx 1000 engine rpm's to see if the snap would
cause slippage, it was "crisp' & sharply brought mower to speed. The mower is free, with engine off I can turn by hand. Pressure gauge on
clutch pack line is showing approx. 560 P.S.I. with lever in on position. What say you? Thanks in advance!
