Changing T boots on 1750 Oliver Diesel
Kevint1564
New User
I have a leak in a T booth on the cylinder that is directly under
the fuel tank toward the battery. How is the the best way to get
at it and what needs to come off?
Remove the top side body panel
and the heat shield if equipped.
Replace all six of them. If one is leaking it wont be long for the rest of them. Start on one end removing T's and connecting lines and install new ones the same way. Start at one end and go to the other. Makes things go much easier.If you've got the wire spring clamps, you'll need the special tool.If you don't want to buy the tool, just replace them with small hose clamps.
