Oliver 1600 LP gas
Looking at an Oliver 1600 LP gas.It does not have a 3 point hitch or hydra power.Tires are under 50%.Was wondering how much a tractor like this is worth.It does have a wide front.
This tractor sounds a lot like it's a Wheatland.   Does it have a non-adjustable front axle and non-adjustable rear tread.   Rear wheels will be mounted on tapered axles.   Wheatland tractors were what we called self-propelled drawbars.
This is not a wheatland tractor.It has an adjustable front end and 38" tires on the back.It has only one remote hydraulic outlet.It is a row crop.Rear axles are adjustable.
55 HP, WF, LPG, no 3 PH, no Hydra-Power, fair to poor tires? I'll guess around $2,500. Much more than that and you could buy a better equipped IH 706 gas or for around $4,000 a JD 4020 gas.
