1958 Oliver 550 lift
J Oliver
New User
Have a Oliver 550 with a lot of problems.Looking for information on the lift. When cold lift will pick up equipment but squeals after lift raises to the top. After tractor warms up lift will not pick up equipment. The hyd system has new oil and filter. Any advice or ideas would be great.
where would be the best location to connect the pressure gauge, if pressure is good what else should I look for? when I got tractor you could move lift control 1" and lift would go to top and sound like relief valve was bypassing until you lowered the control lever. thanks for advice
[quote="J Oliver
engine has rattle in front of engine motor was rebuilt has 125 hrs rattle is loud but does not change any ideas
