2-105 front weight
I don't know if the bolt holes line up or not, but if it bolts on it is going to look funny because on the 2-105 the weight bracket actually holds the
grill therefore the weight bracket is going to stick out a long ways if it bolts on the oliver.
I make the base that bolts on 50/55 series tractors and the weights that go along with them 414 379 8485 terry
I thought it might look funny...but that fits right in with the operator! LOL! I might do it just for fun. Once every two or three years we plow a little. Otherwise it will just sit in the corner of the shed.
A book I have describing the engineering behind Oliver Tractors they were aware of the need for weight up front...the cast iron grill was the answer... :)
(quoted from post at 07:28:25 07/04/17) A book I have describing the engineering behind Oliver Tractors they were aware of the need for weight up front...the cast iron grill was the answer... :)
ary66, I took that grill off when I painted it and oh boy, it's heavy! We have some white weights and I figured if I got the bracket I might use them sometimes...
