Re: 1750 with a 283 Diesel?
J. Schwiebert
Needless to say it is not a 310 direct injection. When you get it home publish the 3 block casting number. It could maybe an 1800 engine (310) as well.
(quoted from post at 01:16:58 06/17/17) Looks to me like it is a '67 model.
yeah that is what I came up with as well. Just trying to figure out what motor is in it. since it is obviously not original. Also is says over under on it but it only has the two position hydra shift.
(quoted from post at 01:37:55 06/05/17) Needless to say it is not a 310 direct injection. When you get it home publish the 3 block casting number. It could maybe an 1800 engine (310) as well.
J. here are the casting numbers on the motor 106085-A(the 6 could be an 8)
221020-D
3101
there appears to be some red paint under the green.
