richlandfarm
Hello all,
Had a chance to hook up the new 1750 to something to try it out and this is what I found so. Far. The PTO will not shut off but I am assuming this is warped clutches. But my main head scratcher is We put it on batwing rotary mower and not sure what is up with the hydraulics. The left set of remotes works with out issue. the right set of remotes will only operate if I shove the three point hitch control to full lift position , then the right remotes work but is also sending fluid thru the left remote. Is this some orings blown out in the hydraulic housing ? Thanks for any help in advance.
