Have had nothing but issues so far this year. Some of you might remember the starting issues on my 1650. Have that worked out. Started cutting hay, broke the tension cable on my Hesston mower, had baler issues, hopefully fixed those. Went and cut some hay last night, mower worked better than it has in a while, brought it back to the house and while backing it up to put it in the shed made a hard right turn with the 1650 and the next thing I know it's locked in a hard right turn. Jacked it up and got it to straighten out, was able to limp the mower into the shed and get the tractor under cover too. Went out tonight to check it out and found it will only turn left. Jacked up the front to take the weight off of it and still have the same thing. Did I lose an O-ring or something in the sector under the front or is the steering motor at fault? It doesn't immediately turn as soon as you start the tractor, just turns left with the steering wheel and then gets extremely stiff when you try to turn right. Any ideas?
