I'll have to buy a new hydraulic pump for the 1365 I guess. I moved bales off the field with it this morning and after an hour,when the oil was heating up,it got so it wouldn't lift a bale.
I went over to the scrap yard to see if they'd crushed that 1250 yet. They hadn't,so I gave them $10 for the pump. It looked the same to the naked eye. I changed the drive hub,slid it in place and put a couple of bolts in it,then discovered the suction line was bigger on the 1365 and wouldn't bolt up. So then I thought I could take two and make one. When I got them apart,I found out the 1365 pump is longer than the 1250 pump so none of the internals are the same.
Oh well. Not the end of the world,or the first time something like this has happened. Devil of it is,now it won't prime again.
