Olliejunkie
Can anyone tell me anything from this id tag?
(quoted from post at 14:14:15 06/12/17) It is not a Super 77, a 232 was used in the 1550/55 engines. A super 77 is 3-1/2 X 3-3/4.
It came out of white backhoe but I don't know if it was original as it looks to have wrecking yard numbers on valve cover and backhoe was yellow.
Maybe the valve cover was changed.
185320 is the Waukesha number, 160 918A is the Oliver casting number. 5244 is the date the block was poured. The block was poured in Charles City.
(quoted from post at 06:00:01 06/13/17) 185320 is the Waukesha number, 160 918A is the Oliver casting number. 5244 is the date the block was poured. The block was poured in Charles City.
Thanks John..wish I knew what it was in originally?. May always be a mystery.
Thanks John..wish I knew what it was in originally?. Hope to get the pump on and fired up this weekend.
Thanks John.Hope to get the pump on and fired up this weekend.
Before you do check to make sure none of the injectors are stuck and I would remove the pump drive shaft and install it and see if the pump is free or you may be out major cash!
(quoted from post at 14:08:14 06/13/17) Before you do check to make sure none of the injectors are stuck and I would remove the pump drive shaft and install it and see if the pump is free or you may be out major cash!
hank you. I will. Came with an extra pump and injectors..
