Mike(NEOhio)
- Location
- Newbury, Ohio
Got the MoCo out and cut some hay today. I have the right side set up for one way and last year it worked fine. Today, at first it was lifting good and I got the line bled out but when I was cutting it would not always lift. Had to work the lever 4-5 times then it would lift OK. Didn't do it all the time. On the steering, when I make a corner and the steering hits the lock and goes on relief, it pulls the engine down. Also forces some fluid out from between the flow control valve and the housing. New O-rings there. Relief valve checked at 1500 psi when I rebuilt it. This is the early flow control.
